SparkandFire
We're drinking beer
This morning I took off from home to trek my way to work. I left later than usual, so of course that means my 25 mile commute will end up taking closer to an hour and a half.
First stoplight I come to, I push the clutch down and... truck dies.
Starts right back up.
Next stoplight I come to... yep, you guessed it... truck dies.
This little game continues pretty much the whole way to work. In stop and go traffic nonetheless. As a result of moving the right hand from the gear shift, to the coffee cup, to the ignition switch, I dumped a "significant quantity" of coffee on myself this morning as well...
If I keep it in gear until right before the stop, engine keeps running. I've got the idle set a little high because I've got one injector that doesn't match the rest (7 new BB injectors from typ4, and one old injector, since I had one get carboned up and stuck in the hole on the 7.3 I pulled out)
The IP is a Uhaul unit with about 8,000 miles on it, I swapped it over to the 6.9 about two months ago, and it's ran good since then.
So, can one injector that doesn't match the rest cause this? It idles kind of rough as it is, the DMF makes noise because of it.
Or is my terrific Uhaul IP got one foot in the grave?
