discbrks
What's the secret to the oil drain tube? I followed the instructions, stuck it in the grommet, then mounted the turbo to the cast iron up pipe. Then you're supposed to bolt the tube to the turbo. But somehow when bolting down the turbo I knocked the drain out of the grommet. To make it worse, I put a bead of gray RTV on the end of the tube.... so now there's gray RTV everywhere. Anyway, I'm gonna keep moving forward with the install, skipping the drain for now. I'll go start the exhaust system. Hopefully someone has a secret to this oil drain.
