Follow the Thunder Pickle
Abull78
More boost Mr. Scot
Nevada
Ok, return trip has started, first stop Tullahouma TN to see Mom and then back to LV. Go Pickle Go
Abull78
More boost Mr. Scot
Nevada
Mpg has gone to crap. Averaging 13mpg, previously I was seeing 17. Any ideas?
Has your turbo boost changed any... What are your tire pressures. Remember you are feeding the turbo unfiltered oil. Thats not a really bad thing but filtered oil would be much better. When you get home maybe its time to remove the main oil galley plug that you couldn't remove before the trip. Even if you need to drill a hole thru it for an easy out it will be worth it. A magnet will be able to remove any metal from the drilling easily.
Abull78
More boost Mr. Scot
Nevada
Boost hasn't changed, did tires, no fuel leaks. Would 4000 miles continuous driving retard my timingg a bit?
No... Not unless the pump slipped in the gear cover because the nuts were not tight enough... Have you changed any fuel additive...
Dsl_Dog_Treat
Decatur,MI
Heck I'm still baffled at 22 psi of boost on the pickles setup......
But who cares what the mileage is.LOL
dyoung14
Is getting worn out
spencer,tn
Welcome to tennessee few more hills around this part;Really lol actually i dont know were you are, guess i should go lookLOL
ntjapkes
