So I found some info in an old post and did the full field test for my voltage regulator. Voltage only went from 11.75 to 12.43, bingo, found the problem. I took it back to auto zone and the guy tested it and confirmed that it was trash. I told him that they should have tested it before they sold it to me 10 days ago. I had him test the new one and it was good. I put it on, fired it up and everything seemed good to go. After checking the voltage at the batteries I took it for a spin and noticed that the ammeter would go way up as the rpm's went up. The headlights and dash lights would also get brighter as the rpm's went up. Is this normal ? If not, any ideas on how to fix this ? As usual, the help is greatly appreciated.
thanks
Rob.
thanks
Rob.
