ghunt
Well about a year and a half after I bought the pump, I finally got the damn thing all installed tonight.
It's a Carter P4070 pump, which is surprisingly quiet, and then an old filter head off a bulldozer with a 32 micron filter as a prefilter. Made a bracket for it so it mounts right behind the transfer case and to the skidplate, and everything seems to be working pretty well.
One question I do have is that I put a gauge on the line right where it goes into the filter head. It's showing about 2 psi of fuel pressure- which is exactly what my old mechanical lift pump was showing when I had the gauge on there before (and here I thought the lift pump was going out). What's the reason for that- bad gauge? It shows a little more than 3 PSI prior to starting the engine, then when I start it it drops down to 2.
