Gare, if Sam's lucky, yes, it should. I know for sure she put in a new o-ring where the turbo meets the pedestal, and I bet the current issue is the valley pan grommet - I think when the engine is cold the grommet sits pretty tight around the pedestal drain tube, however once the engine warms up the grommet loosens up its grip and allows oil to leak out and flood the valley pan and spill everywhere from there. My friend's '86 had a similar issue with that grommet, no turbo on that engine so we never had an Exxon Valdez happen, but the CDR valve was very hard to pull in and out with the engine cold (I borrowed it for my truck once), but once the engine warmed up it was as if that grommet wasn't even there, very easy in and out of the CDR tube. Given that a turbo makes a whole lot of heat right in that area, I'd imagine the rubber grommet dries out faster on turbo trucks than it does on n/a engines.
