Feeding twins oil.
right now i have one turbo being fed from the stock oil sender location
and the other feeding off the banks location drivers side lower.
would you run both off 1 port?
Thewespaul
Bulverde, Texas
Nah feed them seperate. If you’re setting up compounds you can feed them from the front of each head to make the lines shorter and look nicer.
Oledirtypearl86
Whitehall MT
In my opinion I wouldnt unless I was sure that it would be able to supply enough oil my concern would be that if using a t that one turbo would get more oil than the other starving the other because a fluid takes the path of least resistance and I don't know if there is any oil back pressure in the turbo
Crawler
Dallas, TX
I have not run twins/compounds on an IDI. But on all other applications we run separate lines/sources. Also try to make sure that they have separate drains. A merged drain is a bad thing as well.
my drains are plumbed separately, but both return through mechanical pump location.
on the new engine im building, they will both have drains in opposite sides of the oil pan.
Thewespaul
Bulverde, Texas
I think that will be a better route going to the pan then trying to share a drain.
On my compounds I’m going to set a bulkhead in the passenger side valve cover for the atmospheric turbo and the manifold charger will return like stock
truckonfire
