TangTonic
Hey Guys,
I have been without a/c for awhile and finally decided to do something about it. Here's what I know- the fan clutch is not spinning. I can spin it by hand with the truck off. With the a/c on max, voltage gets to the fan clutch terminal when the low pressure switched is jumpered. When the terminal is not jumpered- no voltage. Even with voltage- the fan clutch doesn't spin and a/c blows hot.
So I assume I either have pressure issues or a faulty low pressure switch for one. That doesn't solve the fan clutch problem. Do I need a new fan clutch to get a/c? I don't have overheating issues. Do I just need a shim? Or is my compressor bad? What is the next step in troubleshooting?
Thanks for the help.
