Camarogenius
Okay, so I figured out my running light problem. In the headlight switch, I've got power to the ********* wire w/ the red stripe, and that's powering the headlights. It goes to pole B-1. However, I'm getting no power to the running lights. So, I played around with a jumper, and if I jump from B-1 to B-2, then my running lights work properly. I'm going to hard wire the jumper tomorrow.
Still no dash lights. While I was playing around with the plug/switch, I jumped from B-1 to the blue wire w/ red stripe(I think it was a red stripe, I may be wrong), and for a second, I had dash lights, until it blew a 30A fuse. When I was jumping to the dash lights, I had my thumb on the ceramic wheel for the dimmer/ dome lights, and it instantly got real hot, so I've got a direct ground somewhere, I need to find.
Meanwhile, There's no power from the switch to the dash lights, so I'm going to jump from the switch to running light relay, and run it to the dash light out wire. That way, I'll have power to the dash lights whenever the running lights are on. The one problem I see here is that I may lose my dimmer function. Does anyone have a map of the lightswitch/plug?
Today at the pick-n-pull, I grabbed another headlight relay. I want to wire this one in so that when I click on my high beams, both the low beam and high beams are on. Thoughts?
