ISPKI
I am installing some gages in my 94 superduty. Pyrometer, Oil Pressure, Boost, maybe a couple others. I was wondering about a good place to pull switched power. I ran a 16ga wire (Green wire with Red heatshrink on the end) to a fuse block under the dash to provide what I believe is switched power at the GP relay? Can anyone confirm this post with the large Red/green stripe wire is switched power from the ignition switch?
Only reason im asking is that I went to turn the truck on this AM to see if the gauges were working and they didnt seem to receive any power.
Now, the Pyrometer gage, as far as I can tell, the only power it has is for the light bulb. The Oil pressure gage however, has a red wire for switched power, a yellow wire for constant power, and an orange wire for a dimmer function, and a ground. I had looked up the purpose of the constant power wire and supposedly it is to save the color setting for the gage. I assumed I wouldnt need that wire plugged in for the gage to work but maybe that isnt the case.
