exhaust flanges
those are bigger than the ford ones, but yes that description.
I could cnc a set with the taper in them if needed. The trick would be figuring out the angle of the taper.
it would be the same as the manifold taper, I have a local waterjet place that can do them. But I am getting lots of them hopefully coming from members , very helpful.
Michael Dimock
Grass Valley, CA
Russ, when I rebuilt my up pipes for my Banks setup I ended up using 2x Walker 31885 flanges I got from Summit which are meant for 2.25" pipe and 4" bolt centers. They are bent up the opposite way with the tapered part and folded over edges being the same way, but it fit just fine up to the manifolds. I die grinded the holes out a bit just in case, but I think they would fit w/o mods to begin with. Hope this helps.
Bo17
