Back when I did my brake pads, I didn't think and I used a clamp on a single piston, making them uneven. Then I tried to fix it by using an old pad, like you should. But, I guess I didn't do a good job.
When I was changing the shocks the other day, I found the RH caliper dragging a bit and the outer pad is unevenly worn.
I was lazy the other day and didn't take it all apart, but tried clamping it near the piston sticking out extra by not removing the reservoir cap, figuring the pressure would even out to the other piston. Well, the piston went in a tiny bit and the drag went away. I haven't drive any, so I don't know if it's still uneven or not. Really it needs new pads now due to the uneven wear, but they still have enough pad that I could put it off a year if needed.
The inner pad at the pistons side looks evenly worn, oddly enough.
How do you go about fixing the caliper? You'd think it would equalize under pressure, but I guess not. Maybe the other piston is sticking? Or just not evened out properly? Is there really anything I can do now without replacing the pads? I'm guessing the uneven pads will force it to be uneven now, no matter what I do to it. Warped rotor caused it maybe?
