Ethylene glycol vs. Propylene gycol coolant
tjsea
Lickdale, PA
Which coolant is better? I have been looking at Fleetgaurd's ES compleat line. I don't really want to use the Fleetcool becuase I would rather have the DCA-4 over the DCA-2(just my personal preferance since the Ford stuff is the same as the DCA-4). I know that the PG is less toxic than the EG is to pets and whatnot, but will the PG attack gaskets or o-rings or is it ok.
itsacrazyasian
residentcrazyasian
boca raton, fl
Neither should hurt gaskets. Its the OAT coolants that wreck havoc with the older cooling systems. Propylene glycol is more efficient at heat transfer, Ethlyene has a lower viscosity for improved flow and is better for freeze protection.
I've never used the ES compleat so i can't comment about any ill effects on my motor. I've been using fleetcharge.
lewisstevey7
