Anymore, you gotta read more than just the brand-name on the jug.
Rotella used to be as good as it got; Delo400 was better.
No more, since the advent of CJ-4 requirements.
Up until then, SAE requirements were always backwards compatible, with each successive oil being better for the engine than the preceding one.
With the onslaught of heavily emmission-controlled engines, the EPA decided that there were ingredients in the additives that make oil do it's job so good that were also affecting the effectiveness of emmissions systems.
So, they made the new engines require a new rating, CJ-4.
With this new oil, there has been a number of reportings of prematurely worn-out camshafts, along with a host of other problems.
A few manufacturers still offer oil that is still CI-4 and NOT CJ-4.
CI-4 can still be found in the blue jugs at Walmart; John Deere 15W-40 is still CI-4 rated; Conoco/Phillips still offers it under all three trade names, including trustyworthy Kendall.
If you do run the new CJ-4 oil, change intervals should be halved.
