Oct 8, 2008 #1 F Full Monte Full Access Member Joined Oct 15, 2005 Posts 749 Reaction score 1 Location Campbell, CA Since the article thread is closed, Mel...check the link to the article...it doesn't work for me.
Oct 9, 2008 #2 Agnem Using the Force! Joined Jan 10, 2005 Posts 17,067 Reaction score 386 Location Delta, PA I should know better than to use an off-site link from someone with 8 posts. It's outahere.
Oct 9, 2008 #3 M maxdiesel Guest Are you looking for the article replacing the stock fuel tank selector valve with an auto zone FSV2 ?
Oct 9, 2008 #4 F Full Monte Full Access Member Joined Oct 15, 2005 Posts 749 Reaction score 1 Location Campbell, CA No, it was supposed to be an article replacing the mechanical fuel pump with an electrical one.
