egt and water temp seems too low
frankenwrench
overkill is under rated!
Weatherford tx
OK all back to normal. Think she did a better job on this one cause it's alot more responsive. Was wondering. Does the wicked wheel 2 improve boost numbers on the ats093? Or just respond more at lower rpm?
Without cutting up your front end I would honestly go water to air, I’ve had great experience with them in drag projects and when setup right they work great for the street and even towing
Think of it as a radiator, but instead of the air cooling hot water inside the radiator, the water is cold and cools the intake charge
dieselmainiac
