EGR delete issue's
OLD93
Dennis
Apple Valley, MN
I installed a complete EGR delete kit. It now throw's a check engine light which was kind of expected. The biggest problem is that the back up sensor's no longer function for my wife. Would anyone know if this is a coincidence that the backup sensors just quit at the same time of if they are connected somehow to the CEL? Any suggestion's would be greatly helping our marriage!
Pneuking
Shreveport, LA
Don't unplug the ERG valve. Zip tie her up out of the way and allow it to operate. This satisfies the computer so no codes are thrown. As for the back up sensors, I dunno.
dsltech83
Ellery,IL
No, CEL can't be caused by bad backup sensors, egr delete has nothin to do with the backup sensors
OLD93
Dennis
Apple Valley, MN
I have had the egr valve connected and I mounted it to an empty threaded hole on the neck of the air intake in the open since i did the delete. my guess is that the valve may be bad. I was going to swap a buddy's valve for a test just have not gotten to it yet.
Thanks
bismic1
Texas
This doen't satisfy the PCM for a 2005 year model. It knows all of the expected air flows and system pressures, etc., so it still will think something is wrong. If you delete the EGR system, you really neeed a tuner.
Newman
Gilbert, AZ
I agree! I had the same problem with my 05
Exekiel69
anywhere I can find more info about this? I read a Very long thread on FTE about egr delete but it is a long argument with nothing definite at least at the time I read it.
Thank You.
Brimmstone
I do deletes, headgaskets, and oil coolers about once a week and here is the skinny. 03-04 will not show a code from doing the delete and then leaving the egr unplugged. 05 is a crap shoot. The earlier ones won't throw a code if you do the delete and just leave the EGR plugged in. About mid 05 and up they must be killed with a tuner. I'm sure someone is going to argue with me about this but I do at least 4 deletes a month minimum. I can just about tell on the 05s at this point if will be an issue as the ones that it will throw a code on run slightly different then the others.
polksfinest
lakeland
I know i am new to this forum but I do a lot of these and i agree 100 percent with Brimmstone and make sure you get a tuner that will delete the EGR I had a guy who i installed the delete for him and he install a banks system that did not delete the EGR. It threw codes and even caused it to white smoke like crazzy at idle
Respectfully Submitted
Josh Ballard
Lakeland Diesel
Bryce_Burden90
Shattuck, OK
I am new here as well but we also do alot of EGR deletes on the 6.0s, somewhere I have a list of the tuners that have the capability of deleting the EGR
Bryce
Brimmstone
SCT is about the best out there in my mind. Used them a bunch of times with no problems. Had trouble with others but never with a SCT unit.
Lance
