No, I don't think so..... I think you can use a 4R100 transmission, but you have to use an E4OD solenoid pack and controller. Trackspeeder knows the tricks there...... The 4R100 controller is "part" of the engine PCM for the 7.3PSD. So it uses the engine control inputs to the PCM to control the transmission. For example, the instrument cluster in a PSD is 100% controlled by the PCM, the sensors/senders on the engine do not connect to the gauges, they "connect" to the PCM. Also, there is no physical connection to the engine for the throttle. There is a TPS that is part of the pedal inside the cabin.... so that is where both the PCM and transmission get their throttle position, vs the FIPL on the IP........
