Ole BlackBetty
What is the best bang for the money, stand alone controller?
Sent from my SAMSUNG-SM-N910A using Tapatalk
thanks for the response read my other post about tach you what you think about itThe factory TCM sucks. It gives the E4OD a bad name.
Baumann makes an afordable tranny controller.
If you want to get really fancy there is PCS.
Best thing about any aftermarket controller is gets rid of the factory quirky shift program. All you need is a tach signal,RPM signal, and VSS signal. You're good to go.
With PCS you will need a laptop for programming the controller.![]()
I want to go with the US shift controller. Them and Baumann merged a few years back. My e4od want to lock up the converter way to earlier. There's just not a whole lot of people posting there results and experience with them
Sent from my SM-N920V using Tapatalk
I know the PO stripped the torq heads on TPS. I know not to let it lock that low. Sometimes coming down mine gets down to 1300-1400 but I'm used to hitting the brake to unlock it. I want the controller just to better control it. I've heard people say it makes it shift like a new truck and improvements in MPGs aswellRemember not to lock the converter too early. No less than 1200 RPM. Anything lower will fry the converter, and damage the tranny.
I understand that looked into theses and read the manuals. The only reason I'm hitting brake to unlock is because the stock trans computer is out of whack(I shouldn't have too) because of my TPS. Even a with my tps in working I don't like how stock computer works it. 20 years later and we have better programs and softwares then these 25 year old TCM.With an aftermarket controller you will lose the brake switch to release the clutch. Lock up and release will based on RPM and speed.
