E4od controller
FORDF250HDXLT
Maine & Oklahoma
the one that came as original equipment in your '94 turbo truck.
full
A1 Cardone 73-6104 Replaces Original (OE) Part #:F4TZ 12B565-EA
remans go for about a Benjamin.can't beat that.;)
trackspeeder
Stone crusher.
North Branford. CT
The factory TCM sucks. It gives the E4OD a bad name.:eek:
Baumann makes an afordable tranny controller.
If you want to get really fancy there is PCS.
Best thing about any aftermarket controller is gets rid of the factory quirky shift program. All you need is a tach signal,RPM signal, and VSS signal. You're good to go.
With PCS you will need a laptop for programming the controller.:Thumbs Up
Ole BlackBetty
Norman, Oklahoma
thanks for the response read my other post about tach you what you think about it
Sent from my SAMSUNG-SM-N910A using Tapatalk
FORDF250HDXLT
Maine & Oklahoma
the us shift is $585 + $150 for the harness totaling over 7 times the cost of a reman ford unit at $735 minus tax/shipping so probably closer to 7 and half times a ford reman.......it no doubt is superior,however that can't claim "the best bang for the buck" ;)
Ole BlackBetty
Norman, Oklahoma
The quick 4 is the only one they offer now I guess. I click on the link for the quick 1 and it goes to the quick 4?
Ferd_Diesel
Wisconsin
I want to go with the US shift controller. Them and Baumann merged a few years back. My e4od want to lock up the converter way to earlier. There's just not a whole lot of people posting there results and experience with them
Sent from my SM-N920V using Tapatalk
Not that many people using them.
There's a guy with one on his gm 6.5 and he loves it.
trackspeeder
Stone crusher.
North Branford. CT
Remember not to lock the converter too early. No less than 1200 RPM. Anything lower will fry the converter, and damage the tranny.
Ferd_Diesel
Wisconsin
I know the PO stripped the torq heads on TPS. I know not to let it lock that low. Sometimes coming down mine gets down to 1300-1400 but I'm used to hitting the brake to unlock it. I want the controller just to better control it. I've heard people say it makes it shift like a new truck and improvements in MPGs aswell
trackspeeder
Stone crusher.
North Branford. CT
With an aftermarket controller you will lose the brake switch to release the clutch. Lock up and release will based on RPM and speed.
Ferd_Diesel
Wisconsin
I understand that looked into theses and read the manuals. The only reason I'm hitting brake to unlock is because the stock trans computer is out of whack(I shouldn't have too) because of my TPS. Even a with my tps in working I don't like how stock computer works it. 20 years later and we have better programs and softwares then these 25 year old TCM.
raydav
Apple Valley, CA
I have been using the earlier model Baumann controller for about a decade on both a 460 and 7.3 in a 9K# 84 E350.
Up and down shift points and line pressure are programmable. You have your choice of locking the converter starting in 2, 3, or 4th gear.
And you can create two profiles that are on-the-fly switchable - such as road and off road. I have one profile where the converter locks in second for when I am grinding up a slow road and staying in second or third. For town I don't lock the converter until fourth.
And, if you have cruise control switches on the steering wheel, they can be used as "paddle switches".
ntjapkes
