aiyana7.3
IDI Enthusiast
So awhile back, I posted about some drive shaft problems I was having after lifting my 92 f250 regular cab 4 inches. The transfer case was leaking fluid, the u joints were shot, and the differential needed to be shimmed, after shimming the axle it still looked like this.
After being told that the drive shaft is too short and needs to be extended, I took my truck down to a drive line specialist, they recommended I extend it by 2 1/2 inches. I had the drive shaft extended but now I cant get it back in the truck. I tried jacking the frame up in order to extend the suspension and get a little more distance between the diff and the transfer case but it still seems too long.
Here are some pictures of the drive shaft while the suspension is fully extended.
This is a picture after I took the transfer case seal out and pushed the shaft in until it was maxed out.
Transfer case seal next to transfer case.
This is where the drive shaft is lining up with the differential. Its a little hard to make out due to the tap I have on it to keep the U joint caps on but as you can see it still too long. The shaft wont go in any further than this.
So is this drive shaft too long or is there something I am missing? If it is too long, how much should it be shortened?
Thanks again for everyone's help!
