Take your end mill chuck in a hand drill and tell me how much it pulls to the side. Also a cheap press with side to side play doesn't make a round hole.
There is a lot of sidways force from that cutter. Its a lot different than a drill bit.
Hand drill...*** u talking bout and smokin willis?
Now that's something completely different. It is not desgined for that. Same goes for using a tapered ream I'd only use that for this purpose in a good quality benchtop drill press or as the one I'm looking at buying a nice Radial arm floor standing press. Then with moderate pressure and correct speed things happen nicely.
Using a hand drill for an end mill well that's just W R O N G by any standard...there are tools for the job and hand drills are not one of them. However this procedure is not one for a hand drill really anyway to be accurate and square! That is unless you are using a MAG drill on a big plate bolted to the case! That's different ....
just saying!
You would have to be off a bunch to have issues and using the steel IDI adapter as a drill guide makes it easy. It lines up so close to the outside of the trans case it's easy to see if you are off much. Just my two cents, worked for me.
