Not sure if I can link photos from FTE to here, but here we go since they are the only pics I have hosted on the web..
Stock Ford right, ATS left
Stock Ford Downpipe right, ATS left
I also think you will find the T3 exhaust housings will not work because the bolt pattern is different and the wastegate would create a problem.
No internal waste gate to block the exhaust flow through the port = no boost at all.
Back of stock Ford turbo outlet flange.
That picture also shows why you can't just have the housing milled out to take a larger down pipe.
I guess you could change the exhaust side turbine housing and use the Garrett waste gate housing in Oreo's link, then install a 94 to 97 3" Stroke downpipe.
Oreo and several other people and I have been over this forward and backward several times over on FTE.
However I will admit I never thought about changing the exhaust turbine housing till I just made this post.
ATS changed the housing and outlet flange just enough that you can't go anywhere else for parts.
And unfortunately Ford used the ATS style turbo.
