mexicanjoe
Hey crew got a problem. Old Bessy my 89 F-250 has developed a clanging noise whenever I shift gears. Doesn't happen every time , but enough I had to check it out...,placed the truck in neutral,chocked the tires and crawled under for a look see.... we I can twist the drive shaft and hear some noise from the diff.... it's a 4.10 rear axle so I've never had to deal with this problem. If it turns out ol Bessys tear end us going out( no pun intended) what would be cheaper: buy a used diff or purchase a ring and pinion and hope for the best, BTW who sells ring and pinion at a cheap price ? Thanks!
