Dialing in IP timing for turbo with charge air cooling
What timing does your turbo IDI run best at?
  • Around 6* BTDC
    Votes: 0 0.0%
  • Around 8* BTDC
    Votes: 2 40.0%
  • Around 10* BTDC
    Votes: 1 20.0%
  • Other
    Votes: 2 40.0%
  • Total voters
Thewespaul
Bulverde, Texas
It’s a measurement of the density of the air in your location, so it’s dependent on temperature, humidity and pressure which is constantly changing
You can see that although I am at 1229ft, the density of the air is like that at 3492ft because of the poor air density which is pretty typical for my area this time of year. During the winter, the density altitude goes way up, which in turn drops the density altitude, which often will be a negative altitude, so a sub-terrain air density.
An interesting note, recently I was in a small accident, and was bumped in the front and back of the shop truck, the steel bumper wasn’t damaged but my grill area and front oem bumper was hurt. I installed a used oem grille and a non slotted front bumper and noticed a drop in my volumtric efficiency instantly, with less air flow around the intercooler and radiator, the truck ran 15* warmer, egts were up 200* and boost was up a psi. With the intercooler not cooling as well, less heat was taken from the air charge, which decreased the air density through more heat/pressure at the same rate of volume.
iPhone?? No need for that kind of language around here Wes! Lol :backoff:rotflmao
I have to completely agree with this one. If somebody was to give one to me, I'd take a BIG F'n hammer to it! I had one for two weeks. That is the reason why I'm still using a flip phone. If I would have got one that was worthwhile, I'm sure that I'd be using a smart phone.
tke395
