DB2 vs DB4 pump
Dieselburner 68
Trondheim, Norway
7.3 TIDI
PES8P inline pump
this is going into a 41 1/2 ton ford drag car
Thank you for your answer. What did you do to make the pump fit to the timing cover? Custom make a new timing cover? What did you do to make the gear from the crank shaft fit to the gear from the injection pump? Is the pump direct drivven from the crank gear? The gear on the injection pump, is that a OEM gear to that pump? I am not sure what PES8P stands for. Is that a Bosch P inline pump? Are you competing on the 1/4 mile?
