Have steering issues with yer Solid axle D60 going PoP
This is a product I tried...built for chev and jeep....not Ford sadly
TRE that goes PoP...no boot sure sticks out a ways.....
This plastic part is designed for 1 Ton chev TRE as such it was a gamble to try it...clearly ..not quite right
Now slid back....
Now found this rubber spacer on my OLD worn out linkage it nestles nicely against the cure
And nut tightened down...
So now I tried to convince them to make Ford unitz...nope...
So that being said...the way it is right now much less...MUCH less slop n PoP of my steering.
I think one under each of the 4 TRE would make a huge difference. The TRE only work in 1 plane so why not?
JM7.3CW
Now slid back....
JM7.3CW
