Thank you for the response. The thing that I have been looking at as far as taking the performance to the next level, and one of the major advantages of the IDI over the PSD, is the fact that there are no electronics to hold back the party. I heard about the puller engine that the owner of Hypermax put together a long time ago that got banned because of the way it ran ( something like over 1000hp in an IDI no less ).
Here's the basic plan; make sure that the bottom end is strengthened where it needs to be, maintain the stock static compression ratio, but alter the cam timing so that it can rev out to about 4500-5000 rpms like a gasser. By pushing the hp and torque curves slightly higher than normal ( at least for a diesel ) the pressure curve will be less dynamically down low which will take the strain off the motor and make it less detonation prone saving the head gaskets and pistons while at the same time broadening the powerband and improving power. This way there will be less time for abnormal combustion to occur. I know that at this point it's all theory, but after doing some research about the way diesel combusts inside the engine, the rev limit corresponds well with the limitations of efficient combustion of the fuel and the atomization characteristics of the old school fuel injection system. The only other thing that would be done is to barrier coat the pistons and prechambers to help with thermal losses of the IDI. I don't know if doing the prechambers has been done by anyone else, but I am willing to give it a try to see what would happen.
