blown84
well, today, i took the gauges outta my truck, yet again. last time, i used sharpie on the numbers and whatnot, and under the laredo sunlight, they faded very badly over only a couple weeks. so i redid em, and actually used paint this time. they are now the same color as the needles. while i had em out, i corrected the odometer, since i swapped the speedo from another truck that had the trip meter. and lastly, i added LEDs.
this is when they came out today. notice how light and faded the numbers are. also that the tach needle fell off.
here you can see 12 of the 14 LEDs i used to light the four "vitals" gauges.
i left the 55 and the circle around it for last. you can see just how faded the sharpie was. im never gonna use sharpie for my gauges again.
the gauges are completely repainted and LEDs installed. you can see how i used the flexible strips to go around the tach and speedo.
completely reassembled and ready to go back in the truck. note how you cant see that any of the gauges are lit by LEDs, even with the strips around the speedo and tach.
assembled and installed, it was after dark, and perfect for a night shot. they are almost too bright! (at least the way i wired em, they work with the dimmer. :-X22)
for comparison, this is how they looked before the LEDs.
oh, and i did all the numbers and whatnot by hand with model paints and brushes.
