custom powersteering
does anyone have numbers of volume these stock ford pumps put out?
I want to delete the stock pump and run a TCI style mini PS pump.
with a remote reservoir.
mounting is a non issue.
will be running 2 v-belts.
solid mounted alternator and PS pump
with tensioners.
im thinking about using something like this.
http://www.speedwaymotors.com/KRC-ESP-POWER-STEER-PUMP,280737.html
don't bother asking why.
if youre following my build thread, youll see eventually :D
cpdenton
Truck needs paint.
Conway AR
Found this.
The Ford CII pump (F150-350, Bronco) flows 1.5 gallons/minute at 740 psi. The pressure relief is in the pump and set at 1400 to 1500 psi.
The Ford Saginaw pump (E100-350) flows 1.8 gallons/minute at 620 psi and its relief valve is set at 1350 to 1450 psi.
Found this.
Thanks buddy! I tried searching, but I may be wee-todd-did
this item should fit perfectly infront of the oil cooler.
may need to re-make the water inlet housing.
getting excited about this one...
cpdenton
Truck needs paint.
Conway AR
Me too.
I found that in a thread from 2002. Third post down. It was dumb luck.
kuskoal
Yokosuka, Japan
It's late, you sparked my curiosity and I don't wanna read your build thread (tonight. Tomorrow at lunch is a go :))
But the Saginaw pumps are good enough for crawlers running full hydro and almost decent enough for rear steer(a little slow), why the need for such volume?! The West Texas mod and a smaller pulley will do great for almost anything. Also a bolt in with the van bracket
not really the need for volume.
I have the need for a compact, remote reservoir, and I need to mount it low.
im running hydroboost and steering so I don't want to go low on the flow!
im deleting the conventional belt system and making brackets for both.
kuskoal
Yokosuka, Japan
You'd be fine with the Saginaw pumps, the West Texas mod and a k3500? Pump should be good for it.
Why lower than it already is? Are you building some sorta spaceship? I'm curious now.
yes. spaceship with a twist.
the only Saginaw pumps ive seen have a reservoir
I want a remote reservoir.
http://www.oilburners.net/threads/a-project-i-call-thee-wee-*******.70696/page-7#post-939511
ifrythings
BC
Have you looked into the superduty pumps? Some use the c2 pumps but others have a c3 I believe pump which puts out a bit higher pressure and flow rate and have a remote res.
kuskoal
Yokosuka, Japan
Some sag punps throw out 3.1-3.5 gpm and 1100-1450 psi depending on the pump. I think PSC has a remote can for the sag pumps with the resi mount
ifrythings
BC
Some info on the ford C2 pumps
HBC-JX, HBC-KK
Pressure relief 1400-1530psi
Minimum flow @740psi , 1.4gpm fluid @170F
HBC-JY
Pressure relief 1450-1530psi
Minimum flow @740psi , 1.5gpm fluid @170F
HBC-LC
Pressure relief 1300-1480psi
Minimum flow @740psi , 0.95gpm fluid @170F
Note, flow depends on engine rpm and pulley drive size
I'm not sure how you tell the model of your pump but these are what I found for the C2 power steering pumps.
Some info on C3 pumps used on the newer trucks
2.8-3.2gpm @150psi fluid @165-175F Engine at idle
1.4gpm @750psi fluid @165-175F Engine at idle
Pressure relief 1750-1850psi
m2rtin
