I'm running a 6.9 with a C6 behind it, and a US Gear OD behind that. (.75) with 4.10 gears. Tires are 9.5x16.5 which are about 29.5 inches tall. My Isspro tach says I'm running around 2500 to 2600 rpm at 65-68mph. According to the internet gear calculators I should be at lower rpms than this. Not much, but a little lower. So the questions are, 1. Is the converter loose on these trucks? 2. Is the Isspro tach "off?" 3. Is 2600-2700rpm going to hurt this motor over a long haul?
I have new 235/85r16 tires I'm installing as soon as snow flys, they are about 31.5 inches tall. This will lower the rpm's some. Just curious what rpm's you guys turn.
