Cracked fuel pump cause
Austin86250
idaho
Mechanical for now as it was still under warranty then electric next pay check
Cubey
Van dweller
Maybe you can patch up the hard line with a hose and clamps, depending where it's damaged.
YJMike92
NW Arkansas
IMHO, it was over-tightened or tightened without a backup wrench on the pump fitting. I believe the hardline is the line to the filter. If that is the case there would not be a lot of vibration, unless the filter housing is loose. under the circumstances, I would use a rubber fuel line using the appropriate fittings to make things work.
Got my pump out and not only was it cracked the hardline is spraying diesel out of it now
How can both a fuel pump crack and the hardline break at the same time I’m so lost
Did the bull cream your truck? But yeah that's pretty heavy duty vibration, if it's vibration. Was the nut cross threaded, maybe?
Austin86250
idaho
Is this abnormal vibration?
Good call you guys who recommend putting a rubber line over the hard line, it worked
Another thing to check would be the bolts that hold the bracket that your alternator pivots on. You may have to remove the vacuum pump to get to all three bolts. If those aren't tight, that may allow the filter head mounting bracket to move like that.
One more thing to check is to see if that bracket itself is cracked. I haven't seen that happen, but I suppose that it could.
Austin86250
idaho
All 4 bolts where tight no cracks as far as I can tell
It sure looks like it's wiggling in the video. I watched mine this morning when I started it up and it didn't look like yours, as far as wiggle goes. The filter head isn't loose?
Nanohawk
