ManBearPig
I haven't noticed any adverse symptoms from this, but I've determined my IP timing advance is not working. I didn't even know the truck was supposed to have an advance until I started digging around these forums....dangerous place!!!
I replaced the thermostat in the truck yesterday and realized that would be a good time to mess with the temp switch/sender. I had already confirmed that with the ignition an and engine cold, there was no power to the advance plug on top of the IP. I figured that pointed to a bad switch so I was going to replace it while it was easy to get to with the stat housing out of the way. I pulled the old switch out and tested it, and to my surprise It tested good. The two poles of the switch have continuity when cold, but lose continuity when heated over a boiling pot of water. After the switch cooled down continuity returned. I did this several times to make sure. So I put everything back together and I'm still not getting power to the plug on top of the IP. Weird. Bad connection at the switch? I'm getting power to both wires coming from the switch. The only logical explanation could be a bad wire connecting the switch to the plug atop the IP, right? I gotta say I'm not thrilled about this because that harness is encased in a nice factory loom, and difficult to get to. I guess my question is this....There are other wires intertwined within that harness. I'm wondering if the same wire that powers the cold advance runs anything else that I could test? The previous owner rigged up a manual GP switch and I'm wondering if they somehow intentionally (or unintentionally) disconnected (or screwed up) the timing advance? Is there any other testing I can do before I cut this harness apart looking for a damaged section of wire?
Thanks
Thanks
