Clutch master
S-west
Ct
Ok so I have been feeling with clutch master issues a lot with my truck, 3 cracked plastic ones cracked then I switched to the steel ones then was fine until I did a 5 speed swap and my firewall cracked, after that I installed a reinforcement plate, shortly after the pushrod bent and snapped at the threaded end. I have the heim joint mod on the other part. Anyway that was in august, well yesterday it snapped again and I have to order a new master because they obviously don't sell just the rod. So I plan on taking the new one to the machine shop and have a sleeve made for that section of the master. Anybody else deal with this before?
gonecrazyi
florida
I'm pretty sure Napa sells just the adjustable rod. Sounds like your clutch is hard to push. I've never had a problem cracking masters or bending the rods.
S-west
Ct
2nd clutch, pushes normal until something breaks haha.
truckonfire
