Clutch adjustment help please!
mexicanjoe
texas
Fellow oil burners I need to adjust my clutch on 1989 F-250 w/ZF5 tranny. It has an external slave cylinder but I'm dumbfounded as to adjustments... I hope you can help me out! I have to park it amongst Mercedes and BMWs so as to give them a little class and I enjoy driving it. Gracias, su amigo:mexicanjoe911!
Well, for starters there is no adjustment on any hydraulic clutch....
You should look at the master cylinder rod bushing, as well as the pedal box bushings. But can be found in a site search.
YJMike92
NW Arkansas
If you feel a need for a clutch adjustment there is a problem.
Oledirtypearl86
Whitehall MT
Pull the inspection cover and inspect it if possible have someone push the clutch in a few times slow you might see what the problem is
Edit also what makes your u think it needs adjusted
mexicanjoe
texas
I have a hard time putting it in gear. Reverse is the worst offender and going through the gears isn't much fun. I know how to float the gears but this tranny is not set up for it. It started about 3 months ago and has getting worse incrementaly. Plenty of brake fluid in the master cylinder. I watched the slave as my son operated the pedal. It seems it needs a tiny bit more for the TOB to fully engage maybe?? Help!
DrCharles
West Plains, MO
My truck did this and it turned out to be a failed pressure plate... there only needs to be about 1/2" of movement at the end of the fork. I thought it should be more too, and replaced the hydraulics with a prefilled master/hose/slave. Didn't help.
YJMike92
NW Arkansas
What about the pushrod where it mounts to the pedal assembly under the dash. it is a known wear area. The pushrod has a hole with a plastic bushing which mounts to a stud on the pedal. Very common problem area which can cause what you are describing.
You either need a clutch, replacement master or slave, or firewall repair. Maybe all of the above.
mexicanjoe
texas
Does anyone have a picture of this bushing ? I'm used to mechanical linkages. Those I can work on. Looks like Monday will be spent under the truck
YJMike92
NW Arkansas
I have some pictures of the repair/mod I did on my trucks, but not handy to post. Do a youtube search a lot of videos. The bushing under the dash is mechanical. The plastic bushing wears out then the metal parts start wearing. The more wear under the dash the less pushrod movement under the truck
mexicanjoe
texas
Thanks guys, I'm just concerned that my clutch engages when my clutch pedal clears the floor by millimeters. You just start letting up on the pedal and it starts moving. Not good in heavy traffic. I have to grab 2nd gear as I'm coasting to a stop. . I guess I'll look at the clutch rod and bushing tomorrow.
So here are the pedal bushings.
They go here.
Here’s a picture of the firewall reinforcement plate.
Sometimes this gets worn. May want to search clutch heim joint mod.
Also with respect to the push rod, I did this instead of the heim joint mod.
I drilled it for a bronze bushing. Then I drilled the shaft for a lynch pin. Don’t know if this is any better or worse than the heim mod. There’s a guy on eBay that sells the heim mod.
