Cleaning flywheel bolt holes in crankshaft
WarNose
Bay Area, CA
I just removed my flexplate in preparation for a ZF5 swap And noticed that three of the bolt holes were leaking oil through. How do you guys go about cleaning these bolt holes so that the loctite will seal next time? Do you spray brake cleaner in there and let it get into the oil pan? Maybe drain the oil afterwards? Do you run a thread chaser through the bolt holes and let the old loctite fall into the oil pan? I suppose loctite isn't hard enough to do any damage to the internals?
Clb
Another old truck
nannyfornia
Tin foil shield.
Wire bottle brush?
I must be missing something here.....
How is the oil pan open to atmosphere?
riphip
Memphis, TN.
Spray brake cleaner. It will evaporate. No need for thread chaser. Blue loctite (clean bolts with brake cleaner, apply loctite & let set up before installing)
03wr250f
Hamilton/Montana
Either loctite with brake cleaner or I use permatex aviation rtv its sold by oteillys/napa. It's what ford specifies and it's not like any normal rtv. It's very liquidy but hardens.
Sent from my SM-A015V using Tapatalk
WarNose
Bay Area, CA
Tin foil shield.
Wire bottle brush?
Tin foil shield where? I guess the oil pan is only open to atmosphere through the crankcase ventilation. Hopefully that is enough to let brake clean evaporate. I think I'll use a nylon bottle brush because I'm worried a wire one might lose a piece inside.
It's better to let the locktite harden a bit before installing?
That's not a bad idea!
Clb
Another old truck
nannyfornia
****** ford!
That being the case....
Low pressure air jacked into the top end blowing out of the crank bolt holes?
Clb
Another old truck
nannyfornia
Yes
Little late in the day..
****** harvester!
Farm technology much?
You Gotta make it Idiot Proof on da farm boys (not you Bri):sorry:
Farmer Rock
Glen Rock,PA
Yes
****** harvester!
This here farm boy is having slight trouble decoding this! lol
Rock
Clb
Another old truck
nannyfornia
Well
Us oakies never throwed nuthin away, as such if it could work it was used.
So thinking of having the tractor ran in the row till it quits pulling, then dropping the flywheel to have it turned while getting a new clutch pac ordered up or pulled off the shelf, and not realize the bolt holes go into the block.....
Think of the dust storm shoving grit in there.
WarNose
Bay Area, CA
Okay I completely over thought this. A 3/8" diameter nylon bottle brush with brakleen sprayed on it worked very well. I used three all together. Hardly any brakleen made it into the engine I'm sure. A .40 caliber nylon bore brush would have worked well too.
Buffetkiller
Washington
Hey just wondering i just did my rear main(not al the way finished yet) and i used this for crank to flywheel bolts. Ok? Or not?
720Diesel
