I changed my glow plugs in my 97 7.3 powerstroke today and now the truck runs like it could be skipping. Could it be a lose wire under the valve cover gasked or what?
Is the check engine light on? A wire may have gotten pinched under the valve cover, or simply loose. An injector kill test preformed by someone with the proper diagnostic equipment would narrow it down to atleast a specific bank, if not the specific injector.
UVCH is your best bet to examine since you were under there. The connector has a way of coming loose easily. On the lock on the connector, that plastic arch, slip a piece of 3/8" tubing 1/2" long under it, that will keep it locked.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
