CDR Explained
tapdancewilly
Sisters Oregon
It leaves puddles, haha and decent ones too. I saw that kink, the PO rednecked the crap out of this truck and thrashed it sadly
Sent from my XT1055 using Tapatalk
thx997303
utah
The Army wants all service done at regular intervals. Nothing like people dying because something broke. Yeah it wastes a lot of money, but that's not abnormal for a government agency. (In response to IDIBRONCO)
here are some pics of what happens when you attempt to clean the CDR with strong solvents.
bottom line, when in doubt...just replace the damn thing. attempting to clean it will have negative results.
jaluhn83
I messed around with the pictures in your original post, and I think I got them to come up in a test post in the testing forum. See if they come up for you here.
http://www.oilburners.net/forums/showthread.php?66845-IDI-CDR-pictures&p=777133#post777133
If they work for you, then here's the list of the pictures.
http://www.oilburners.net/forums/attachment.php?attachmentid=44952&d=1368857010
http://www.oilburners.net/forums/attachment.php?attachmentid=44954&d=1368857251
http://www.oilburners.net/forums/attachment.php?attachmentid=44955&d=1368858132
http://www.oilburners.net/forums/attachment.php?attachmentid=44956&d=1368858323
http://www.oilburners.net/forums/attachment.php?attachmentid=44957&d=1368858367
http://www.oilburners.net/forums/attachment.php?attachmentid=44958&d=1368858440
If you want to go back and fix your first post, take the above links and copy and paste them in where you want them, and before you are done, put a [ i m g ] in the front of the link, and a [ / i m g ] at the tail end of the link. But type the img bracket code without the spaces I put in. That will tell the board to bring the picture up automatically in your post.
f-two-fiddy
Duluth, Mn.
So just got this truck. It was set up with a road draft tube I believe its called. It had that filter on it which seems to be a irrigation filter haha. Except it leaks oil really bad! I want to put it back to normal and have it run into the intake. But I am concerned because all the oil that it leaked, I don't want that in the intake obviously. So this must have something to do with a messed up CDR right?
That setup is severely in adequate. The crimped hose coming off the CDR at such a sharp angle is prolly only 1/2" of diameter for the gases to flow thru.
