travelinman31
I've read some have cleaned the CDR valve. I pulled mine off today because I noticed some oil on the soupbowl. I can blow air through both holes, no restriction when blowing on either side. I'm thinking a new one is what is needed. When I took it out there is a tube that goes in to the valley pan, does this tube pull off the unit or does the new one come with it? I didn't get forceful but the tube wouldn't just slip off.
I finally got the roof on my shop that I've been building so I can now work on the truck in the dry if it's raining and also get out of the blistering sun down here in Texas. So be prepared I will be asking a lot of questions in the upcoming days. I need to have the truck in tip top shape by Wed. night. Hope everyone is checking the forum on the 4th as that's when most of the work will be done. I have to replace brake pads, bleed brakes, install new injectors, new return lines, new fuel pump, new fuel filter, oil change, check tranny fluid, check rear end fluid, install oil pressure gauge, install pyrometer, may put on new shocks. Man I hope I can get it all done.
