Carrier Pump Group Buy
zpd307
Zumbrota, MN
is the screen removeable to clean/ how is it cleaned. i am assuming the screen will filter well enough to keep the pump alive for a good long while.
zpd307
Zumbrota, MN
let me know when i can get one. this will definately be easier that what i was scheming. how are those of you mounting it on the frame. fabbing any brackets, etc.....
6 Nebraska IDIs
Doug, I want one of these ASAP. Sent you a PM, please get back with me ASAP.
Thanks!
MUDKICKR
NITRO WV 25143
ok, i just read through all this thread and it seems these pumps are the way to go. but i havent seen anyone say how well they do with wmo or tranny fluid, and if someone did run wmo through one of these pumps would it be better on the frame or under the hood? if it will work with wmo i would buy one. just let me know please cause im starting to get my diesel ready for this year, i have a lot of out of state towing to do.
6 Nebraska IDIs
Most everyone is mounting these in the engine compartment. But with any electric pump they work better pushing that pulling so Im torn on where Im going to mount mine.
I know one member was running an 80-20 (80% WMO) mix of WMO in one of these and it quit working on him, not to harp on him, but 80-20 is too thick IMO to run through a single pump and expect it to last very long. These are definitely the best pump I've ever researched.
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
There have been a couple of failures only when running high levels of wmo (trans fluid may not affect it at all) and having the pump up in the engine compartment. Not sure which was more responsible, or if either was. I may be moving mine down to the frame as a CYA. Plus I won't be running more than 50% at the most.
Shadetreemechanic
Monteagle, TN
Pump came today. I am going to try to put it down on the frame to avoid some of the wvo failure mentioned in another thread. It sure looks like a good pump.
Thanks
tke395
