Carrier Pump Group Buy
Torinojts
Canistota SD
I tested my faucet fuel pump the other day (new pump 10 hrs on it), was curious what fuel PSI was. Installed a new fuel filter spliced a t in line right before the injection pump. I installed a mechanical transmission pressure test gauge that will read from 0-40 PSI. With KOEO fuel PSI was reading 10.25 psi. started truck and it dropped to 10 psi. just sitting I reved it up to 2500RPM and it would drop to 7 PSI. My gauge test hose is not long enough to run into the cab, so I tapped it to the windshield. pulled out of my shop and it was dark out so I could not see the gauge. Backed it back into the shop and decided to just power brake the truck and see what it would do. I mashed the pedal to the floor and right before the tires let loose the needle plummeted to 0 psi. I let off the throttle and slowly stepped back into it. When RPMS were reaching 2,000 RPM i was already down to 1 psi, any more throttle and drops to 0 psi. I am going to scrap the Faucet and get a Holley Red installed.
Torinojts
Canistota SD
I had that pump on before this post started, my project has just taken this long to get road worthy. I was going to change it out with a Walbro or Holley Red before first start, but I wanted to try it first. Sometimes projects just turn into a money trap, try things then several months later find information on it and how they sometimes don't work. The Facet was free so cant blame me for trying it first.
tke395
