Carrier Pump Group Buy
RLDSL
Diesel fuel abuser
Arkansas
Well, I finally found my fuel pressure regulator and pressure gauge today, so I set out to see if running the thing regulated down to stock lift pump pressure made any difference in the injection timing over running the pump unregulated.
I checked the timing running the pump wide open, then regulated down to 4.5-5 psi. If I REALLY used my imagination ( and I'm talking all the imagination of someone at the end of opening day staring at a doe trying to grow antlers on it :D ) it might have retarded the timing 1/4-1/2 deg regulating the pressure down.( that ferret doesn't dampen the pulses so you always get some variance , quite honestly, it looked the same, but I'm trying to give the " changes timing " theory the benefit of the doubt )
All that means is running one unregulated might advance your timing by 1/4-1/2 deg. Nothing to worry about ( and if my other theory is correct, a little advance on this new fuel wouldn't hurt a thing ) When I got done checking everything, I reset my timing to 10.5 deg btdc so see how it will act on the ULSD.
The injection pump and injectors on my engine only have around 6-7000 miles on them, and the filter less than 500 miles on it, so this was checked with a healthy injection system.
M
maxdiesel
Guest
Would it make any difference in the output pressure if the pump was mounted under the hood vs on the frame rail?
Full Monte
Campbell, CA
Doug,
Is there any news on delivery of the two pumps I ordered? Haven't heard anything in the last week. Thanks!
Full Monte
Campbell, CA
Doug,
Is there any info on my 2-pump order? It's going on two weeks and I haven't heard anything. Did you get my PayPal payment?
Thanks!
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
Doug,
Thanks!
Hey Monte, I've sent a couple of emails to him and have not gotten anything back yet. It must be a nasty computer virus. I did get your payment and hopefully I'll get news shortly. He's been very good for the last 30 or so pumps, so this is very unusual and I haven't sent him any payment for the 9 pumps everyone is waiting for, so I know he's just having some major issues. Let me know if you can't wait and I can cancel your payment. Again, sorry for the delay.
RLDSL
Diesel fuel abuser
Arkansas
The rated output pressure is at maximum lift., and you won't be sucking fuel anywhere near that high no matter where you stick it on the truck.
mcbg
az
gimme gimme
I would like one of these.
any idea how they handle heat say 160F?
are you going to be suppling these for awhile?
thanks
mcbg
az
any ideas of how much heat these can handle?
hopefully they can go as far as 160F- anybody tried heating them?
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
thanks
As long as my contact has them I'll make them available. I don't know what heat they can handle, but they are designed to live in a small box with a diesel engine running 24/7, but then the fuel may be helping keep them cooler.:dunno
tke395
