haubert
Too cold to work in the garage, got a little time for a proper introduction, I have a 93 f350 crew cab dually 2WD 7.3 Idi with the e40d 280,000 miles bought the truck a year ago I didn't get any history with the truck, but it's not molested, body is good, not a spec of rust on the bottom side, that really superised me so the first thing I done was undercoat, I bought the truck to pull my 12,000 lb 5the wheel camper, it does OK,other than ******* fuel cruises nice on the flat at 75 till it comes to a slight upgrade, I replaced glow plugs and controller ordered a set of b injectors just ordered a kit for oil analysis, when I replace injectors will do compression test to find out if motor is worthy of moose pump and pulse turbo kit, thanks in advance for help and tech info
