Cant get trans codes on my obs!
Desert Diesel Dog
Nevada
"shifts hard"
VACUME MODULATOR PROBLEM ???
In the past, I have had a few automatic transmissions that weren't shifting right and I changed the ‘VACUME MODULATOR’. They shifted fine after that.
It is very easy to change… it just attaches from the outside. The outside part is round and roughly 1 ½ inches in diameter.
Also… these Modulators are not very expensive… maybe still less than $20 these days. [I think I only paid about $12 & $16 a long time ago]
I am certainly NOT an expert with automatics. Your transmission might not even have a Vacuum Modulator. BUT… you might want to check into this. IF… this is the problem, it might be an ‘easy fix’.
I don't think the E40D has a vacuum modulator.
Unconfirmed, but I've heard bad map or clogged ebp tube/bad sensor can cause hard shifting. But again, it's just what I've heard.
fordbrother95
dreams of smoke
hope ks
Now my truck as of right now has a map sensor code in the ecm, would it be worth it to try changing mine out?
Sent from my DROIDX using Tapatalk 2
fordbrother95
dreams of smoke
hope ks
Yeah 35 at napa priced one the other day just didnt know if it was worth getting or not thank you i will go ahead with one!
