leswhitt
I start and shut down on my mix, I'm not running 50/50 like you though. My preference is W80-W82, it's just slightly thicker than diesel and I've started it in the 20's with no problem. I suspect it'll work down into the teens and probably the single digits, it takes just a little bit longer than regular D2 does. As for the engine thinning the fuel mix, I've also heard that the fuel is warmed in the heads before being sent through the return line back to the tank but I've never seen an actual temp number to know just how much it's being warmed up.
I do know this though; I've changed a fuel filter in cold weather on my IDI and it still felt cold (not ice water cold, but cold) on my hands and not warm at all. Maybe the PSD's are different but the IDI's don't make a measurable difference on the "ungloved hand" test.
