May 30, 2019 #1 Danielle No, it's not finished Supporting Member Joined Jul 7, 2011 Posts 2,140 Reaction score 1,000 Location Dirty Jersey 02 E450 rwd I need to add one of these. Do they only go in the top or also on bottom? You must be registered for see images attach
May 30, 2019 #2 DaveBen Supporting Member Supporting Member Joined Sep 29, 2010 Posts 1,928 Reaction score 645 Location Ukiah, Ca The Camber bushings go only in the top. They can be adjusted (turned) to change the camber amount.
May 30, 2019 #3 Danielle No, it's not finished Supporting Member Joined Jul 7, 2011 Posts 2,140 Reaction score 1,000 Location Dirty Jersey Awesome thank you so much! Hopefully the one that allows for 2.25 degrees will get this truck back on the road!
Jun 4, 2019 #4 u2slow bilge rat Joined May 8, 2007 Posts 1,833 Reaction score 820 Location PNW Are your springs sagging? That's usually the source of the camber change.
Jun 8, 2019 #5 greenskeeper Full Access Member Joined Mar 16, 2013 Posts 995 Reaction score 202 Location PA camber (unless ridiculously out) doesn't wear tires as much as improper toe
