Camber sleeves on top and bottom?
Danielle
No, it's not finished
Dirty Jersey
02 E450 rwd
I need to add one of these. Do they only go in the top or also on bottom?
DaveBen
Ukiah, Ca
The Camber bushings go only in the top. They can be adjusted (turned) to change the camber amount.
Danielle
Dirty Jersey
Awesome thank you so much! Hopefully the one that allows for 2.25 degrees will get this truck back on the road!
u2slow
bilge rat
Coastal BC
Are your springs sagging? That's usually the source of the camber change.
greenskeeper
PA
camber (unless ridiculously out) doesn't wear tires as much as improper toe
Staff online
