C6 to Zf5 conversion
Dillonn
South Texas
Ok so it looks like this conversion is the easiest way to get the OD. I haven't run across any bolt in autos that will do it. Any suggestions as to the easiest way to do this? Junk yard?
Donor truck or junkyard. Don't forget to get the aluminum plate on the trans tunnel too. It's WAY easier than cutting a hole in your floor. It will bolt in place of the one in your truck now. I used windshield adhesive to seal mine back down in my Bronco. You might be able to find something else that works too.
