Michael Fowler
If I am committing to fix the truck, I think I need to look at the tranny, too. It shifts fine. But I have severely overheated it a few times. ( It always seems to be on the way to an IDI rally!?) I always change the fluid after getting it hot.
Is it likely that I have damaged the friction linings?
Should I pull the tranny (C6) with the engine--or is it better to pull the engine separately?
Is a C6 something an amateur can go thru, or does it require special tools?
What should I expect to pay for having someone rebuild it, if I have it out of the truck for them?
Does it make good sense to replace the converter while I an there? What do they cost? Is there anything special to look for? Are there choices?
I tow a 7000 lb or so 5th wheel.
