Bw 1356 indexing ring
BigBlueOBS
Anyone ever clocked a bw 1356 transfer case on a 93 f350? I have searched for hours now and I can't find anything helpful. I need to clock it to add 3" more lift for my driveshaft to hook up because my drive shaft is at max angle. Pics please!!! And I also need to know if I need to do anything to the linkage. Please and thank you!
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
biggest issue would be the oil pump inside the case. but all older fords use the same bolt pattern. if you wanted to try, you can get a clocking ring for a 205. I have one in my truck to clock the tcase up to make me a flat belly.
what are you going to do for a cross member after clocking it since the front output will be right into the crossmember
http://www.northwestfab.com/NP205-Round-Ford-Down-GM-Up_p_15.html
BrannonB
